We are loading Thinkgeo map's by default in Decimal Degree ..so..I want to load base map by default in Google Projection ( Meter and/ or Spherical Mercator)...So that I can avoid converting each lat and long to respective Google projections.I knew its possible in Web Application .....using WmsLayer.ActiveBasLayer we can set the base layer to Google Projection. Is this something similar possible using WPF Google Layer???if not ...Do we need to convert each lat and long using ConvertToExternalProjection??
wpfMap1.MapUnit = GeographyUnit.Meter;
wpfMap1.CurrentExtent = new RectangleShape(-14180662, 5547256, -7832569, 1777465);
GoogleMapsOverlay googleMapsOverlay = new GoogleMapsOverlay();
wpfMap1.Overlays.Add(googleMapsOverlay);
ManagedProj4Projection proj4 = new ManagedProj4Projection();
proj4.InternalProjectionParameters = ManagedProj4Projection.GetWgs84ParametersString();
proj4.ExternalProjectionParameters = ManagedProj4Projection.GetGoogleMapParametersString();
double Longitude = -96.80;
double Latitude = 33.50;
proj4.Open();
Vertex googleMapVertex = proj4.ConvertToExternalProjection(Longitude, Latitude);
proj4.Close();
InMemoryFeatureLayer inMemoryFeatureLayer = new InMemoryFeatureLayer();
inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.Red, 12);
inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
inMemoryFeatureLayer.InternalFeatures.Add(new Feature(googleMapVertex));
LayerOverlay dynamicOverlay = new LayerOverlay();
dynamicOverlay.Layers.Add("PointsLayer",inMemoryFeatureLayer);
wpfMap1.Overlays.Add("DynamicOverlay", dynamicOverlay);
wpfMap1.Refresh()
