I just updated a solution from ThinkGeo 8 to 10 and can no longer find the GraticuleAdornmentLayer.
Would someone please help me locate this class?
Thank you.
Thank you.
Hi Klaus,
You just need install this package:
And if you found many package cannot be found, you can also install our xxxx-Standard, it include all of our packages.
The xxxx-BareBone just install the core package and you need to install other package manual.
Ethan, the Layers.Graticule module does not have the GraticuleAdornmentLayer which I also believe is related to WPF. Please clarify.
Hi Klaus,
I build a simple sample for you, you can see the GraticuleAdornmentLayer is included in the package Layers.Graticule.
9521.zip (101.3 KB)
Ethan,
Thanks for taking the time to compose the example. I am wondering if you are referring to the GraticuleFeatureLayer. I simply cannot find the GraticuleAdornmentLayer. I have changed my code to leverage this new construct and will advise accordingly/ Thanks for the help.
