A follow-up question to What properties need to be set when changing projections?
What is the proper way to use track and edit layers when drawing/editing features when other layers are projected? I noticed if I set the projectionconverter on the tracklayer to match what the other layers have, the feature does not appear while drawing. If I don’t set anything, I see the “track” fine, but I’m unsure what projection the internal features are in?
For instance, say I have the mapunit set to meters, and all my static layers have an internal wgs84 and external 3857. If I want to draw a feature using the tracklayer and then move it to one of the static layers, what would I have to project the feature to?
Just a reminder this is for v13.1.2, not on 14 yet.
