I am using the heat map to achieve a visual display that can be based on values and I would like to be able to identify the centoid of the heat bubles inside the current bounding box! Do we have anything that could play a role of heat-seeking function that could enumerate all the heat bubles from the highest to the lowest temperature and of course return their centroid?
thanks a lot.
jm
