HelloWortd: ArrayTypeMismatchException
I just downloded the free Map suite MVC Edition, i'm building my first hello world application according the Quick Start Guide. I created an Empty  MVC 4 Web Apllication (i don't have MVC 3 installed), i created the HomeController and the Index view.
Running the application i get the following error:
Server Error in '/' Application.
Tentativo di accedere a un elemento come tipo incompatibile con la matrice.
               Description: An unhandled exception occurred during  the execution of the current web request. Please review the stack trace  for more information about the error and where it originated in the  code.
 Exception Details: System.ArrayTypeMismatchException: Tentativo di accedere a un elemento come tipo incompatibile con la matrice.
Source Error:
Line 9:
Line 10:     @{
Line 11:         Html.ThinkGeo().Map("Map1", 600, 500) Line 12:         .MapBackground(new BackgroundLayer(new GeoSolidBrush(GeoColor.FromHtml("#E5E3DF"))))
Line 13:         .CurrentExtent(-131.22, 55.05, -54.03, 16.91)
 Source File:  d:\Repositories\Examples\MapHelloWorld\MapHelloWorld\Views\Home\Index.cshtml    Line:  11
Stack Trace:
[ArrayTypeMismatchException: Tentativo di accedere a un elemento come tipo incompatibile con la matrice.]
   System.Collections.Generic.List`1.set_Item(Int32 index, T value) +30
   System.Web.Routing.RouteCollection.SetItem(Int32 index, RouteBase item) +60
   System.Collections.ObjectModel.Collection`1.set_Item(Int32 index, T value) +116
   ThinkGeo.MapSuite.MvcEdition.HtmlHelperExtension.ThinkGeo(HtmlHelper helper) +58
   ASP._Page_Views_Home_Index_cshtml.Execute() in d:\Repositories\Examples\MapHelloWorld\MapHelloWorld\Views\Home\Index.cshtml:11
   System.Web.WebPages.WebPageBase.ExecutePageHierarchy() +207
   System.Web.Mvc.WebViewPage.ExecutePageHierarchy() +97
   System.Web.WebPages.WebPageBase.ExecutePageHierarchy(WebPageContext pageContext, TextWriter writer, WebPageRenderingBase startPage) +76
   System.Web.Mvc.RazorView.RenderView(ViewContext viewContext, TextWriter writer, Object instance) +258
   System.Web.Mvc.BuildManagerCompiledView.Render(ViewContext viewContext, TextWriter writer) +115
   System.Web.Mvc.ViewResultBase.ExecuteResult(ControllerContext context) +303
   System.Web.Mvc.ControllerActionInvoker.InvokeActionResult(ControllerContext controllerContext, ActionResult actionResult) +13
   System.Web.Mvc.<>c__DisplayClass1a.<InvokeActionResultWithFilters>b__17() +23
   System.Web.Mvc.ControllerActionInvoker.InvokeActionResultFilter(IResultFilter filter, ResultExecutingContext preContext, Func`1 continuation) +260
   System.Web.Mvc.<>c__DisplayClass1c.<InvokeActionResultWithFilters>b__19() +19
   System.Web.Mvc.ControllerActionInvoker.InvokeActionResultWithFilters(ControllerContext controllerContext, IList`1 filters, ActionResult actionResult) +177
   System.Web.Mvc.Async.<>c__DisplayClass2a.<BeginInvokeAction>b__20() +92
   System.Web.Mvc.Async.<>c__DisplayClass25.<BeginInvokeAction>b__22(IAsyncResult asyncResult) +126
   System.Web.Mvc.Async.WrappedAsyncResult`1.End() +57
   System.Web.Mvc.Async.AsyncControllerActionInvoker.EndInvokeAction(IAsyncResult asyncResult) +45
   System.Web.Mvc.<>c__DisplayClass1d.<BeginExecuteCore>b__18(IAsyncResult asyncResult) +14
   System.Web.Mvc.Async.<>c__DisplayClass4.<MakeVoidDelegate>b__3(IAsyncResult ar) +25
   System.Web.Mvc.Async.WrappedAsyncResult`1.End() +62
   System.Web.Mvc.Controller.EndExecuteCore(IAsyncResult asyncResult) +61
   System.Web.Mvc.Controller.EndExecute(IAsyncResult asyncResult) +49
   System.Web.Mvc.Controller.System.Web.Mvc.Async.IAsyncController.EndExecute(IAsyncResult asyncResult) +10
   System.Web.Mvc.<>c__DisplayClass8.<BeginProcessRequest>b__3(IAsyncResult asyncResult) +28
   System.Web.Mvc.MvcHandler.EndProcessRequest(IAsyncResult asyncResult) +49
   System.Web.Mvc.MvcHandler.System.Web.IHttpAsyncHandler.EndProcessRequest(IAsyncResult result) +9
   System.Web.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute() +8970141
   System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously) +184
Do i miss something?
HomeController.cs
using System;
using System.Collections.Generic;
using System.Linq;
using System.Web;
using System.Web.Mvc;
namespace MapHelloWorld.Controllers
    public class HomeController : Controller
        // GET: /Home/
        public ActionResult Index()
            return View();
Index.cshtml
@using ThinkGeo.MapSuite.Core
@using ThinkGeo.MapSuite.MvcEdition
    ViewBag.Title = "Index";
<h2>Index</h2>
<div>
        .MapUnit(GeographyUnit.DecimalDegree)
        .CustomOverlays(overlays => overlays.WorldMapKitWmsWebOverlay())
        .Render();
</div>
 Hi Giuseppe,
Thanks for evaluating our products and welcome to the discussion forum. The problem is that some configurations of Asp.NET MVC4 are missed in the web.config file when we take empty Mvc template. To resolve the problem, please add the following configuration to web.config, between "<configuration> ... </configuration>":
  <runtime>
    <assemblyBinding xmlns="urn:schemas-microsoft-com:asm.v1">
        <assemblyIdentity name="System.Web.Mvc" publicKeyToken="31bf3856ad364e35" />
        <bindingRedirect oldVersion="1.0.0.0-4.0.0.0" newVersion="4.0.0.0" />
      </dependentAssembly>
    </assemblyBinding>
  </runtime>
If it doesn't work for you, please do some changes to the "publicKeyToken" and the versions to make sure it fits the one you are using.
Thanks Johnny for your help, now it works.
In the xml you posted there was same tag error, this is the correct version:
  <runtime>
      <dependentAssembly>
       < /dependentAssembly>
     < /assemblyBinding>
   < /runtime>
Giuseppe
Hi Giuseppe,
 Great to hear the problem is solved, and thanks for your sharing, if you have any more question, please feel free to let us know.
 Best Regards
