Hiding Google Map when overlayed by shape file
I have set up a page with a shape file overlaying the Google Map, just like the "ShapeFileOverGoogleMap" sample.  I would now like to be able to "turn off" the Google Map, leaving only the shape file showing.  I want to do this via a check box and a postback, as opposed to the layer switcher like the "BaseLayerChangedEvent" sample does.  I thought that the IsVisible property of the GoogleOverlay or CustomOverlays classes might do the trick, but it doesn't seem to work.  Any suggestions?
Thanks in advance!
Tom
if (!Page.IsPostBack)
Map1.MapBackground.BackgroundBrush = new GeoSolidBrush(GeoColor.FromHtml("#B3C6D4"));
Map1.CurrentExtent = new RectangleShape(-19200000, 14000000, 19700000, -10500000);
Map1.MapTools.MouseCoordinate.Enabled = true;
GoogleOverlay googleOverlay = new GoogleOverlay("Google Map");
googleOverlay.JavaScriptLibraryUri = new Uri("maps.google.com/maps?file=api&v=2&key=ABQIAAAAoxK_HcqphMsnUQHEwLwHlRSavkNJi0NVTgm4UDidoiIU5dUJpRQW88FufPCp0aTPraxZgZFAIUHn3Q");
googleOverlay.GoogleMapType = GoogleMapType.Normal;
ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(MapPath("~/App_Data/cntry02.shp"));
worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.SimpleColors.Transparent, GeoColor.SimpleColors.Black, 1);
worldLayer.FeatureSource.Projection = proj4;
Map1.DynamicOverlay.Layers.Add(worldLayer);
Map1.CustomOverlays.Add(googleOverlay);
protected void cbShowGoogleMap_CheckedChanged(object sender, EventArgs e)
if (!cbShowGoogleMap.Checked)
// this doesn't seem to work...
GoogleOverlay googleOverlay = (GoogleOverlay)Map1.CustomOverlays.First();
googleOverlay.IsVisible = false;
// this doesn't seem to work either...
Map1.CustomOverlays["Google Map"].IsVisible = false;
else
// turn it back on...
Tom,
We can implement this by adding the javascript function as following. Also here attached the sample code, any more queries please let us know.
<script type="text/javascript">
        var OnMapCreating = function(map){
            Class.Extent(mapParser.prototype, {
               initBaseOverlay : function(baseOverlayId){
                           if(baseOverlayId&&baseOverlayId!='undefined'){
                               var layer = this.map.getLayer(baseOverlayId);
                               if(layer){
                               this.map.setBaseLayer(layer);
                               if(!layer.initVisibility){
                               layer.setVisibility(false);
                       getSphericalOverlay : function(json){
                    var creator = new SphericalOverlay(json);
                    creator.createOverlay();
                    creator.element.initVisibility = json.visibility;
                    return creator.element;
</script>
134-4818ForTom.zip (93.9 KB)
Thanks, Ben!!
 That ‘secret’ JavaScript code did the trick!!
 Tom
That’s great. Just let us know for any more queries, Tom.
