I'm testing the latest 3.0.117 Beta 2. I'n drawing shapefiles over Google Maps and I have some performance issue.
When I put a ShapeFileFeatureLayer over the map with only classbreakstyles and different ZoomLevelSet, the application works with acceptable performance. But when I add a HighlightOverlay, in Firefox 3 the application has a high loading time and then the highlights appears with a delay, in IE7 instead the page becomes unusable.
I've attached my sample project (remove the last .zip extension on all files, the multispan archive has been made with 7zip), in the real application I need to put more than one layer over the map using difefrent ZoomLevelSet.
Furthermore I have to add graphs and click events. Am I doing something wrong? How can I speed up my application?
One last question: what about ShapeFileFeatureLayer over Virtual Earth map? What kind of projection do I have to set? Regions don't match with the VE map...
Thanks in advance.
Fabio
141-ICRDemo.zip.001.zip (195 KB)
142-ICRDemo.zip.002.zip (195 KB)
143-ICRDemo.zip.003.zip (194 KB)
