HighlightOverlay Click Event error
Hi
I'm having problem when click on feature in HightlightOverlay. It give me error "Error binding to target method. "
ArgumentException: Error binding to target method.]
   System.Delegate.CreateDelegate(Type type, Object target, String method, Boolean ignoreCase, Boolean throwOnBindFailure) +7575934
   System.Delegate.CreateDelegate(Type type, Object target, String method) +12
   ThinkGeo.MapSuite.WebEdition.HighlightFeatureOverlay.x7f7af3ab7e11f7b1(Object x28db80135f012008) +160
   ThinkGeo.MapSuite.WebEdition.Map.x1b5e287cf1b2ac62() +71
   ThinkGeo.MapSuite.WebEdition.Map.LoadViewState(Object savedState) +681
   System.Web.UI.Control.LoadViewStateRecursive(Object savedState) +183
   System.Web.UI.Control.LoadChildViewStateByIndex(ArrayList childState) +134
   System.Web.UI.Control.LoadViewStateRecursive(Object savedState) +221
   System.Web.UI.Page.LoadAllState() +312
   System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1661
Do you have any idea for this error?
bv
Bv,
 Sorry, we can’t recreate your issue; we have an installed sample of how to use the click event of highlight overlay at:
 websamples.thinkgeo.com/Samples/Overlays/AddClickEventToHighlightOverlay.aspx
 If there are still problems, please provide us the version and the code you are using.
 Howard
