How can I add a compass to my Map?
Yale,
I want to add a compass on my map on top right corner.but I found that I
cant't find any information about compass in api document.
I want to known the following questions:
(1)Is thinkgeo support adding a compass on my map on top right corner?
(2)I knnow that RotationProjection class can rotate a feature layer. How can I rotate a raster layer with a cetain angle ?
for example: WmsRasterLayer.
(3)I only found that RotationProjection class can rotate a feature layer.If my map contains many layeys,I have to rotate every layer with RotationProjection class.
Is there a funtion to rotation my map once?
I'm excepting your reply,thanks very much.
Senlin,
Hope my following can helps:
1)  About the compass, we have a sample, you can take a look at
code.thinkgeo.com/projects/show/compass
2) As you said in questions 2, the RotationProjection can only apply to a FeatureLayer. And we do not support the RasterLayer rotation now.
3) In a map which contains many feature layer, you have to set the Rotation Projection for each layer. And each rotation will be done on the fly every time.
Yale,
  I need to  rotation  a RasterLayer ,can you give me some suggestions.
  can you add the follwing function in next realse version?
  rotate a map  (including feature layer and raster layer)
 thanks very much!
Yale,
 thanks very much!
Yale,
 I  takes a look at code.thinkgeo.com/projects/show/compass,but I can’t download the attached file: Rotating Compass New Smaller Designs.zip
Yale,
 I  takes a look at code.thinkgeo.com/projects/show/compass,but I can’t download the attached file: Rotating Compass New Smaller Designs.zip.
Yale,
Senlin,
  I am going to post them here for you.  See if you can get them.
1332-Rotating_Compass_New_Smaller_Designs.zip (65.6 KB)
