How can I edit features in the displayed shapefile when using Custom Shapefile Indexes?
I would like to display the road network to my users and allow them to edit individual link speeds. I have all the road types in one shapefile.
I am using the index feature to display the different road types with different styles as in the sample here
wiki.thinkgeo.com/wiki/File:...100120.zip
My code
var motorwaysLayer = new ShapeFileFeatureLayer(shapeFileName, motindexFileName,ShapeFileReadWriteMode.ReadOnly);
var primaryLayer = new ShapeFileFeatureLayer(shapeFileName, primindexFileName, ShapeFileReadWriteMode.ReadOnly);
var secondaryLayer = new ShapeFileFeatureLayer(shapeFileName, secFileName, ShapeFileReadWriteMode.ReadOnly);
etc.
 This all works fine when displaying, but when I try to edit the values it all fails. If I change the motorways layer to be ReadWrite opening it throws the exception that file is in use by other process when I do this
motorwaysLayer.Open();
mapControl.CurrentExtent = motorwaysLayer.GetBoundingBox();
motorwaysLayer.Close();
What is the proper way to edit features in this scenario ? Or do I have to create separate shapefiles and than remerge them ? Or is there some other way how to display different types of roads differently with the same shape file ?
Thanks for any hints given.
Thomas,
Thanks for your post.
I think there would be some problems if we are trying to open the same target shape files with both readonly and readwirte modes even it is working perfectly when multiple users are consuming it with ReadOnly mode, this is the same rule as what .net library has done against the disk files. As you said it definitely should work if we can achieve this by using the separate shape files and then remerge them at the appreciate time.
While personally a better solution is probably by using the service, any end users cannot be allowed to edit the file directly , what they can do is just trying to send a edit request to the service which is responsible to the edit it, this is just what I thought, I am not sure it can help in your case.
 Thank Yale,
you confirmed what I have to do now. The only problem is that the shapefiles might have to get remerged, because of at the moment unknown performance of multiple shape files layer, when creating the routing graph.
I plan to have one user at a time. Creating the service would be an option, but at this moment I have to keep this simple (and since I don't have the experience to create a service in a reasonable time I'll have to pass that way).
Tomas
Tomas,
Thanks for your response, please go ahead with your idea; I think it is correct and practical.
