I would like to know if there is a way to load an overlay with an Autocad file? format is DWG.
jm.
jm.
Hello Jean-marie,
The Map Suite FDO Extension is able to partially support Auto CAD file, only DXF format.
So you can use the “OgrFeatureLayer” to load DXF files.
But we do not have support for 3D shapes, so if your DWG file save as 3D, I think it’s no way to read it, but if you are save as 2D, you can use some software to transfer it to DXF file then try with MapSuite.
Sorry for the inconvenience,
