Yale, thinks very much for your reply! I want to use the TileCahce to speed the map dispaly,so I prepare to generate the tiles ,the scales must be fixed, otherwise when I use the TileCahce ,it cann’t user the tiles that had generated.the speed is still slow. but the scale is double type, it doesn’t fixed when I am using your method of the sample. how can I resolve this problem? I find that the old version 2.6, I can disable the automatic MouseWheel support by the following code: MapControl.MapWheelSupport = false; in the new version ,I can’t find the MapWheelSupport Property ? I’m excepting your reply ! thank you very much!
I agree with you that if the scales are not set correctly, it will affect the performance because of lacking in tiles. So I suggest you use the preset scales shown in my application.
In 3.x version, we use the following way to forbid mouse wheel: winformsMap1.ExtentOverlay.MouseWheelMode = MapMouseWheelMode.Disabled;
