How do I work with linear route data in ArcGIS shape file?
I recieved a shapefile today to enhance the accuracy of my data as an addition to a shapefile of point features that I already have. I was told that this is 'routing data'. I can use Map Suite Explorer and visualize the files together and everything is where it should be. I am able to load the files and have the correct projection in my application as well.
The points are highway reference posts and the linear data are the calibrated lines of highways. My goal is to get the X and Y of post 113.5 (or 113.2, etc) along my line which is between points 113 and 114 in my point shapefile. My point file has only the integer values of the posts and not the tenths. If there is a (better) way to do this using standard TIGER/Line shapefiles I would be happy to use them instead. Independant of using TIGER or ArcGIS linear data, how would I determine the point, along the line, at the specified fraction of a distance between points on the line?
Thanks for your help!
 Even if I did not understand everything from your explination, it sounds like that you need to apply Dynamic Segmentation to your linear data. We have a project in the Code Community Dynamic Segmentation that should help you even if it may not answer exactely to your question. If you still have doubts, let us know.
code.thinkgeo.com/projects/s...gmentation
I attempted to use the Dynamic Segmentation sample to work with the data. When trying to use LineOnALine to get a portion of my line I am getting the complete line - not just the segment. That is I believe the root of my issue. I am unsure as to whether the problem is me, a method, or the data.
 I have created support ticket 2565 because I cannot post the data publicly.
Thank you for creating the Support ticket. I will personally look at this.
