How i can overwritte the .rtg file
I have a big problem i'm trying to ovverwrite the .rtg file for (Austinstreets.rtg) but i don't know how i think the Geomedia will help me in doing that but it can't open it what program i should have to do that.
i'm building a website for my graduation  project and I use your product and my dissection in sunday so i need a fast and good help please thanks.
mohammad AL-Amour.
Hi mohammad,
Thank you for your post. Do you need to generate your own .rtg file to overwrite the old one, or you need to modify the .rtg file? If you just need to generate .rtg file, you can use static method (GenerateRoutingData) to meet your requirement.
public static void GenerateRoutingData(string rtgFilePathName, FeatureSource featureSource, BuildRoutingDataMode buildRoutingDataMode)
Please let us know if you have further questions.
Ivan
 HI Ivan,
No i want to modify the old one i just want to add a new feild to show  if the street avilable and i want to be able to modify it whenever  a notice come that the street is avilable.
THANKS FOR FAST ANSWER,
Mohammad,
Hi mohammad,
In your scenario, you don't need to modify *.rtg file, you can add a column to shape file and modify column's value to meet your requirement, just as the code did in "How Do I Samples/Edit Routing Index file". Please check the following steps:
1. Add your own column to shape file
featureSource = new ShapeFileFeatureSource(@"..\..\..\SampleData\Austinstreets.shp", ShapeFileReadWriteMode.ReadWrite);
featureSource.Open();
featureSource.AddColumnString("yourColumn", 50);
featureSource.Close();
2. Use your own logic to modify customized column's value (for example, modify the clicked feature)
routingSource.Open();
Collection<RouteSegment> routeSegments = routingSource.GetRouteSegmentsNearestTo(clickedPosition, featureSource, winformsMap1.MapUnit, 1);
if (routeSegments.Count > 0)
    string featureId = routeSegments[0].FeatureId;
    Feature feature = featureSource.GetFeatureById(featureId, ReturningColumnsType.NoColumns);
    feature.ColumnValues["YourColumn"] = "YourColumnValue";
    featureSource.BeginTransaction();
    featureSource.UpdateFeature(feature);
    featureSource.CommitTransaction();
Please let me know if you have further questions.
Ivan
