How to Add histogram to CreateGRID Sampls
Any suggestion for adding a histogram to the CreateGRID sample?
Ideally the color of the bars would reflect the colors in the heat map.
f
Hi Frobe,
Thanks for your question!
You might want to check our the ZedGraph library whose API we expose in Map Suite. ZedGraph is a very powerful graphing library and should provide you with any graphing options you could need.
Check out this Wiki entry for a sample implementation: wiki.thinkgeo.com/wiki/Map_S...s#Zedgraph
Additional information about ZedGraph's API can be found at: zedgraph.org/wiki/index.php?title=Main_Page
