How to add TextStyle to CustomStyles
hello,
 I have probably missed something ...
 I get this error when I try to add a TextStyle to a CustomStyles :
The value for the enumeration is not on of the valid values.
Parameter name: style
mylayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(TextStyles.CreateSimpleTextStyle("TEX", "Arial Narrow", 10, FontStyle.Bold, GeoColor.StandardColors.Gray))
But the same TextStyle applied to DefaultTextStyle  works.
mylayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.CreateSimpleTextStyle("TEX", "Arial Narrow", 10, FontStyle.Bold, GeoColor.StandardColors.Gray)
Thank you for your help !
Eric,
 I think this problem should be caused by other part of your code.
 I tested your style and works well.
 And please change FontStyle.Bold to DrawingFontStyles.Bold.
Don,
 This is the solution, without you I still look a long time!
 FontStyle.Regular (works in VB and not in C #) = 0
 which is not an acceptable value for DrawingFontStyle.
 And replacing with DrawingFontStyles.Regular = 1, it works.
 Very good point, thank you!
Eric,
 You are welcome.
