How to cancel currently drawing shape
Hi, I wanted to implement a cancel functionality to our application.
I tried subscribing to the Map Keydown event, however it never triggers when pressing a key.
Map.TrackOverlay.MapKeyDown += Map_KeyDown;
private async void Map_KeyDown(object sender, MapKeyDownInteractiveOverlayEventArgs e)
        Map.TrackOverlay.TrackShapeLayer.InternalFeatures.Clear();
        try
            await Map.RefreshAsync(Map.TrackOverlay);
        catch { }
I also tried subscribing to
Map.KeyDown += Map_KeyDown;
private async void Map_KeyDown(object sender, KeyEventArgs e)
however, that breakpoint is also never hit. I couldnt find anything in the HowDoI, so could you please assist me?
Map Implementation is
        </ContentControl>
Can you try Map.ExtentOverlay.MapKeyDown for a quick?
Hi Ben, I just tried
Map.ExtentOverlay.MapKeyDown += OnKeyDown;
and it also does not fire an event.
Please first, make sure the map is focusable
mapView.Focusable = true;
then either focus it programmatically:
mapView.Focus();
or do
mapView.MapFocusMode = MapFocusMode.MouseEnterFocused; to make it automatically being focused.
In fact, we’ll make it Focusable by default in the future versions.
Oh, yeah, that worked, thanks! Is there a performance benefit of keeping it not focusable? Wondering if it is worth it only enabling that during draw operations
No, there’s no meaningful performance benefit. You can keep it true.
