How to change the color of Markers
Hi
I currently have multiple brands of stores which i have allocated an HTML color to.
I have used a popup marker to show my stores as i require the popup to show information on the stores once the users hover over the marker.
The issue i am having is getting each store brand to show as a different color marker.
This is the code i am using to loop through the data and add the style to the marker for each brand
        For Each myStore In myHHStores
            If myStore.ColumnValues(“SubBrandid”) = 1 Then
                StoresMarkerOverlay.FeatureSource.InternalFeatures.Add(myStore.ColumnValues(“Id”), myStore)
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.ContentHtml = “[#StoreName#]([#StoreCode#])]”
                'StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle =
                'StoresLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.FromHtml(Color), 10)
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.HasCloseButton = True
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.Width = 100
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.Height = 30
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.BackgroundColor = GeoColor.StandardColors.Green
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.BorderColor = GeoColor.StandardColors.Black
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.Popup.BorderWidth = 1
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage.ImageOffsetX = -10.5F
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage.ImageOffsetY = -25.0F
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage.ImageWidth = 21
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage.ImageHeight = 25
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage.FontColor = GeoColor.FromHtml("#99FF99")
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.DefaultMarkerStyle.WebImage.TextBackgroundColor = GeoColor.FromHtml("#99FF99")
                StoresMarkerOverlay.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
            ElseIf myStore.ColumnValues(“SubBrandid”) = 2 Then
            ElseIf myStore.ColumnValues(“SubBrandid”) = 3 Then
            ElseIf myStore.ColumnValues(“SubBrandid”) = 4 Then
            End If
        Next
Please could you assist
Hi Ismail,
 If you want to render marker to different color based on your data value, please try to use ValueMarkerStyle or ClassBreakMarkerStyle.
 You can see we have a sample named SetTheZoomLevelsOnAMarker which tells how to use ClassBreakMarkerStyle.
