How to check if mouse click is within certain screen pixels (20) from a location on map?
HI ThinkGeo
How to check if mouse click is within certain theshold screen  distance in pixels (let' say 20) from a location on map? In my scenario I don't have map width/height set in pixels as it adjusts to size of the browser window size.
Anil
Anil,
 I would check the two Code Community samples Get Feature Clicked On (Web) and Get Feature Clicked On (Web) 2. Those two samples show how to get the features within a certain distance in screen coordinate based on where the user has clicked on the map. And I think those samples pretty much respond to your expectation. Thank you.
wiki.thinkgeo.com/wiki/Map_Suite_We...n.28Web.29
wiki.thinkgeo.com/wiki/Map_Suite_We....28Web.292
Hi Val,
 As I mentioned in my post that I do have Map Width and Height are not valuated and hence I cannot use method ExtentHelper.ToScreenCoordinate().
 In my case I am using AJAX server callback method to retrieve the nearest features and not a Post back method.
 Anil
Anil,
  Sorry for not reading more carefully your requirements. I will get the assistance this afternoon from a programmer of the Web developement team for the exact solution. You should hesr back from us at the latest tomorrow. Thank you.
Hi Val,
 I am able to resolve solution by  passing in the extent and width/size from the browser to the server and then use ExtentHelper methods .
 Anil
Anil,
 You are welcome, if you have any more questions please let us know again,
 Scott,
