When I tried to connect to server I got a message: "Login failed. Connecting server failed or timeout, please try again later."
I thing that the problem is the proxy behind the firewall.
How to config the proxy manually?
Thanks in advance.
Fabio Pires.
I got the answer by myself. I added the lines below in the file MapSuiteGisEditor.exe.config:
‹system.net›
‹defaultProxy useDefaultCredentials="true"/›
‹/system.net›
Anyways, thanks.
Thanks Fabio! We will add this as an option on our next version so you will have a check box in the general options to set this instead of having to add it to the settings file manually. Please let us know if you have any other issues or feedback. Thanks!
