How to control the Zoom based on the Mouse Wheel evevt
Hi ThinkGeo,
By Default, on  Mouse wheel rotate will lead to several levels lead to full zooom in/out.
How to control the zoom level if the user rotates mouse wheel very fast?
I tried to set
Anil
MouseWheelEventArgs.Handled = true if the time interval between two events is very small say 200 in the handler for PreviewMouseWheel event. This does filter out the actual MouseWheelEvent firing. Is there a better way?
Hi Anil,
My method is kind like yours; but I did it by rewriting a new ExtentInteractiveOverlay. Here is the code. Hope it helps.
public class CustomExtentInteractiveOverlay : ExtentInteractiveOverlay
    private DispatcherTimer timer;
    public CustomExtentInteractiveOverlay()
        timer = new DispatcherTimer();
        timer.Tick += (o, e) => { ((DispatcherTimer)o).Stop(); };
        timer.Interval = TimeSpan.FromMilliseconds(200);
    protected override InteractiveResult MouseWheelCore(InteractionArguments interactionArguments)
        InteractiveResult result = base.MouseWheelCore(interactionArguments);
        if (timer.IsEnabled)
            result.NewCurrentExtent = null;
            timer.Stop();
        timer.Start();
        return result;
Here is the code to use it.
Map1.ExtentOverlay = new CustomExtentInteractiveOverlay();
Please let me know if you have more queries.
Howard
