Thank you for your post, but sorry to say, we don’t have the method to insert/modify/delete a column. We used to have this function in Map Suite 2.0 but as dbf structure itself is not suitable for adding/removing columns, to implement that, internally we need to create a new dbf file, copy all the data there and replace the original file. This method is easily to be abused and it has a low performance. For example, if I want to add 2 new columns and call AddColumn() method twice, internally it will do the copies twice. That’s a reason we removed this method in 3.0 kind of reminding people DBF is not suitable to do this operation, if you implement it by yourself, you can have a better performance and have a good understand about the logic behind the scene.
