How to delete a FeatureLayer
I my application, I have a botton to allow user load a shapefile.
I use the following code to create a ShapeFileFeatureLayer
ShapeFileFeatureLayer wellboreLayer =
new ShapeFileFeatureLayer(m_shapeFileName);"Wellbores";new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Red), 10);LabelOverlappingRule.AllowOverlapping;ApplyUntilZoomLevel.Level20;new EventHandler<DrawingFeaturesEventArgs>(shapeFileFeatureLayer_DrawingFeatures);false;LayerOverlay layerOverlay = new LayerOverlay();"WellboreFeatureLayer, wellboreLayer);
winformsMap1.Refresh();
These code throw exceptions.
System.IndexOutOfRangeException: Index was outside the bounds of the array.
   at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.x03e3d48bcfe7bb6c(IEnumerable`1 xa6f0db4f183189f1)
   at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.xff5b27c00f9678c2(RectangleShape x178b193eec228e6e)
   at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.xe3cee4adb9c72451()
   at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.x9ac8c50f434f4b39(Int32 xb565f4681f05557a)
   at ThinkGeo.MapSuite.DesktopEdition.WinformsMap.Refresh()
What would cause the Index was outside the bounds of the array exception?
In my catch, I want to find the FeatureLayer and delete it.
FeatureLayer  layer =  winformsMap1.FindFeatureLayer("WellboreFeatureLayer");
How to delete this layer?
Thank you.
Katherine
wellboreLayer .Name =
wellboreLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle =
wellboreLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle.OverlappingRule =
wellboreLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel =
wellboreLayer.DrawingFeatures +=
wellboreLayer.RequireIndex =
layerOverlay.Layers.Add(
winformsMap1.Overlays.Add(layerOverlay);
Katherine,
  • Thanks for your post.
There are two ways to remove the feature layers:
1) Set the target layer as invisible. This way will be convenient when you want to set it back to visible if required.
winformsMap1.FindFeatureLayer("WellboreFeatureLayer").IsVisible = false;
2)Remove the layer from the LayerOverlay. When use this method, you have to set the keys for the LayerOverlay and Layer.
((LayerOverlay)(winformsMap1.Overlays["WorldOverlay"])).Layers.Remove("WellboreFeatureLayer");
About the reason throwing the exception, I think it probably indicts there is some error in your index file. If possible, could you send us your shape files?
