How to Delete inMemoryFeatureLayer?
hi
I am plotting lines using multiple coordinates in an array. after i plot successfully i wanted to delete whole "inMemoryFeatureLayer" from the map and wanted to redraw lines using different coordinates.i just learnt how to delete feature from Inmemory layer or editing features. but how i can delete the InMemoryFeatureLayer or Overlays wanted to know ?.below is the code the way i m plotting line using multiple coordinates.
dim i as integer
       For i = 0 To rows
            LineShape.Vertices.Add(New Vertex(stlon(i), stlat(i)))
        Next
        Dim inMemoryFeatureLayer As New InMemoryFeatureLayer()
        inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle.OuterPen = New GeoPen(GeoColor.FromArgb(200, GeoColor.StandardColors.Red), 5)
        inMemoryFeatureLayer.InternalFeatures.Add("Line", New Feature(LineShape))
        inMemoryFeatureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
        Dim lineOverlay As New LayerOverlay()
        lineOverlay.Layers.Add("Line_imfl", inMemoryFeatureLayer)
        winformsMap1.Overlays.Add(lineOverlay)
Zeeshan
ZEESHAN,
You’d better add a key to each layer/Overlay, so you can delete them easily. Just like the following code, "Line_imfl" isthe key of inMemoryFeatureLayer,
"overlay" is the key of lineOverlay.
            WinformsMap1.Overlays.Add("overlay", lineOverlay)
Here is the code you want.
lineOverlay.Layers.Remove("Line_imfl")    'remove inMemoryFeatureLayer from lineOverlay
            WinformsMap1.Overlays.Remove("overlay")   'remove lineOverlay from WinformsMap
