How to find points in a cluster
  I have used cluster point style in inmemorfeature layer containg location.I need to find points in that a cluster i click over.Plz tell me the way to achieve this.
Regards
I maen i need to find all the points in the cluster i click
    I need to do this in my project , that on click of cluster point i need to find all points inside that cluster.I need to do this on urgent basic.plz help
    Plz let me know if its possible.If yes how
     Plz reply …
Hi Vivek,
 One way to do this would be through a Spatial Query. Using the YourLayer.QueryTools you could use the GetFeaturesWithinDistanceOf() to return you all the features from within a distance of a clicked location.
But clustermarker style takes pixcel as criteria for selecting points to include.How can i use distance in that case
Hi Vivek,
 Assume the GridSize is 50 px, so in this zoomlevel the distance = Map1.CurrentScale / 96 * 50 / x, x = 12 when Mapunit is Feet, x = 39.3701 when MapUnit is Meter, otherwise x = 4374754. Here you have the distance then you can use the spatial query.
 Edgar
