Another quick one: Is it possible to find the internal and external SRID of a projection object?
TIA,
Klaus
TIA,
Klaus
Klaus,
Thanks for your question!
For your case, you need to find the correct SRID number for the projection what you are using first, currently, we don't have a easy way to find the SRID value for internal parameter string or external parameter string. Please check the documentation within “C:\Program Files\ThinkGeo\Map Suite Desktop Full Edition 5.0\Documentation\Projections\EPSG.rtf”.
Also that's a good suggestion for us, if you think that is a good addition to Map Suite, please feel free to suggest it on our enhancement tracker at:
helpdesk.thinkgeo.com/EnhancementTracker
and see if the Map Suite community will give it any votes.
Scott,
