How to get endpoint on route
Hi I have the following function that takes a list of destinations and find the one with the shortest route.
Is it possible to mark the start and end point on the result?
I have the start point but is there any method on the routingresult to get first and last point? (endpoint)
On the addRouteToMap i need to show the destination.
public static RoutingResult GetShortestRoute(PointShape startPoint, List<Feature> pointDestinationList)
    var _route = new RoutingResult();
    double dist = -1;
        foreach (var item in pointDestinationList)
            var endPoint = item.GetShape().GetCenterPoint();
            var tmpRoute = GetRoute(startPoint, endPoint);
            if (tmpRoute.Distance < dist || dist == -1)
                dist = _route.Distance;
                _route = tmpRoute;
    return _route;
public void AddRouteToMap(RoutingResult request, PointShape startPoint)
    LayerOverlay routingOverlay = new LayerOverlay();
    var routingLayer = new RoutingLayer();
    routingLayer.Routes.Add(request.Route);
    routingLayer.StartPoint = startPoint;
    //routingLayer.EndPoint = ???;
    routingOverlay.Layers.Add("RoutingExtentLayer", routingLayer);
    winformsMap1.Overlays.Add("RoutingOverlay", routingOverlay);
    winformsMap1.Refresh();
- Niels
Hello Niels,
 Once you get the RoutingResult in your method AddRouteToMap, and you know the start point, you can simply get the first features and the last features in the RoutingResult.Features, because start point and end point are always the first point and the last point, so compare with your startpoint, you can get the end point.
 Hi Gary, I can't find the right data in the feature set.
Here is my get route function, but looking in the routingResult.Features i don't see any usefull x,y ??
public RoutingResult GetRoute(PointShape startPoint, PointShape endPoint)
    RoutingResult routingResult = new RoutingResult();
    ShapeFileFeatureLayer dkRoadsLayer = new ShapeFileFeatureLayer(dkRoads);
    dkRoadsLayer.Open();
    RoutingSource routingSource = new RtgRoutingSource(dkRoadsIndex);
    var algorithm = new DijkstraRoutingAlgorithm();
    RoutingEngine routingEngine = new RoutingEngine(routingSource, algorithm, dkRoadsLayer.FeatureSource);
    routingEngine.RoutingResultsType = RoutingResultsType.RouteSegmentsAndFeatures;
    routingResult = routingEngine.GetRoute(startPoint, endPoint);
    dkRoadsLayer.Close();
    //using servicestack.text to write .Dump()
    Console.WriteLine(routingResult.Dump());
    return routingResult;
osm_id: 25783817,
lastchange: "1970-01-01T00:00:00",
code: 5114,
fclass: secondary,
ref: 255,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 25783817,
code: 5114,
fclass: secondary,
ref: 255,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 25783817,
code: 5114,
fclass: secondary,
ref: 255,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 25783817,
code: 5114,
fclass: secondary,
ref: 255,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 25783817,
code: 5114,
fclass: secondary,
ref: 255,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 29233465,
code: 5122,
fclass: residential,
ref: ,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 29233465,
lastchange: "1970-01-01T00:00:00The thread '<No Name>' (0x450) has exited with code 0 (0x0).
code: 5122,
ref: ,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 29233465,
code: 5122,
ref: ,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 29233465,
code: 5122,
ref: ,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 29233465,
code: 5122,
ref: ,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 29233465,
code: 5122,
ref: ,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 29233465,
code: 5122,
ref: ,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 29233465,
code: 5122,
ref: ,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 29233465,
code: 5122,
ref: ,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 29233465,
code: 5122,
ref: ,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 28093098,
code: 5114,
fclass: secondary,
ref: 255,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
osm_id: 28085249,
code: 5114,
fclass: secondary,
ref: 215,
oneway: F,
maxspeed: ,
layer: 0,
bridge: F,
tunnel: F
OrderedStops: [],
Route:
Lines:
Vertices:
"X:  11.7476; Y: 55.5510",
"X:  11.7494; Y: 55.5515",
"X:  11.7558; Y: 55.5535",
"X:  11.7566; Y: 55.5538",
"X:  11.7591; Y: 55.5549"
CanRotate: True,
Vertices:
"X:  11.7473; Y: 55.5509",
CanRotate: True,
Vertices:
"X:  11.7465; Y: 55.5506",
CanRotate: True,
Vertices:
"X:  11.7231; Y: 55.5438",
"X:  11.7326; Y: 55.5466",
"X:  11.7420; Y: 55.5493",
CanRotate: True,
Vertices:
"X:  11.7196; Y: 55.5428",
CanRotate: True,
Vertices:
"X:  11.7170; Y: 55.5435",
"X:  11.7177; Y: 55.5436",
"X:  11.7182; Y: 55.5435",
"X:  11.7189; Y: 55.5433",
"X:  11.7194; Y: 55.5430",
CanRotate: True,
Vertices:
"X:  11.7169; Y: 55.5435",
CanRotate: True,
Vertices:
"X:  11.7161; Y: 55.5434",
CanRotate: True,
Vertices:
"X:  11.7153; Y: 55.5433",
CanRotate: True,
Vertices:
"X:  11.7151; Y: 55.5433",
CanRotate: True,
Vertices:
"X:  11.7138; Y: 55.5434",
"X:  11.7142; Y: 55.5433",
CanRotate: True,
Vertices:
"X:  11.7113; Y: 55.5437",
"X:  11.7120; Y: 55.5436",
"X:  11.7133; Y: 55.5435",
CanRotate: True,
Vertices:
"X:  11.7096; Y: 55.5438",
"X:  11.7104; Y: 55.5438",
CanRotate: True,
Vertices:
"X:  11.7093; Y: 55.5438",
CanRotate: True,
Vertices:
"X:  11.7087; Y: 55.5437",
CanRotate: True,
Vertices:
"X:  11.7085; Y: 55.5438",
"X:  11.7082; Y: 55.5438"
CanRotate: True,
Vertices:
"X:  11.7082; Y: 55.5438",
"X:  11.7080; Y: 55.5441"
CanRotate: True,
CanRotate: True,
Distance: 4055.57418166185,
Weight: 0,
Features:
ThinkGeo.MapSuite.Core.Feature,
RouteSegments:
Weight: 848.1918,
RouteSegmentType: 0,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
StartPointAdjacentIds:
98243,
617162
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
EndPointAdjacentIds:
98245,
465203
FeatureId: 98244,
DrivingDirection: Forward
Weight: 19.89538,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
98242,
600547
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
98244,
617162
FeatureId: 98243,
Weight: 56.41431,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
98241,
465207
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
98243,
600547
FeatureId: 98242,
Weight: 1652.494,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
98240,
144145
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
98242,
465207
FeatureId: 98241,
Weight: 250.0562,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
98239,
161984
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
98241,
144145
FeatureId: 98240,
Weight: 204.5791,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161983,
333128
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
98239,
98240
FeatureId: 161984,
DrivingDirection: RightForward
Weight: 8.356613,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161982,
617044
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161984,
333128
FeatureId: 161983,
Weight: 47.82912,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161981,
637949
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161983,
617044
FeatureId: 161982,
Weight: 55.38148,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161980,
571462
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161982,
637949
FeatureId: 161981,
Weight: 7.922089,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161979,
637944
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161981,
571462
FeatureId: 161980,
Weight: 86.52647,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161978,
571470
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161980,
637944
FeatureId: 161979,
Weight: 161.6161,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161977,
571466
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161979,
571470
FeatureId: 161978,
Weight: 109.0097,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161976,
333121
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161978,
571466
FeatureId: 161977,
Weight: 16.31941,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161975,
177744
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161977,
333121
FeatureId: 161976,
Weight: 40.54268,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
147405,
147406
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
161976,
177744
FeatureId: 161975,
Weight: 36.42773,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
147405,
161975
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
147249,
147407
FeatureId: 147406,
Weight: 454.0123,
StartPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
147406,
147407
EndPoint:
X: 0,
Y: 0,
Z: 0,
CanRotate: True,
147250,
600286
FeatureId: 147249,
Hello Niels,
 My apologize, it’s not Features, you should get:
     routingResult.Route.Lines
 then get the first line and the last line, check it’s vertices, remove the vertex which connect with second line and last but one line, then you will get what you want.
