I use string strId=layer.EditTools.Add(newFeature); to add a new feature into .shp file.
returning strId is something like "wer234 wet345 ert456 er345". but when i use GetAllFeatures() method, It turns out that the real inserted id for this feature is a string digit like 251.
Is there a way to retrieve real inserted id of the feature when i just added it?
Hi Reza,
If you view the API you can see the comment for it: This string is the ID that will uniquely identify this Feature while it is in a transaction.
So this id is not the real id for the added feature.
You can get the feature from layer again and know its id.
