How to get specific distance on the lineShape
Hello all,
I'd like to get vertex of specific distance on the lineShape.
for example, as follows picture.
I have one LineShape.
And I can use GetPointOnLine to get next Vertex(V1).(distance=2 Meter)
Then, I'd like to use V1 to get the next vertex in 2 meter distance on the lineshape.
how to do it?
Have any idea to help me?
Carol,
Thanks for your post.
As far as my understanding, the GetPointOnALine API should fix your problem; the key part is passing correct distance which is calculated from the first point of the LineShape. As your example, when you want to get the second vertex, you probably need to 4 meters (2 m + 2m), hopes that make sense.
Carol,
If we want the midpoint( vertex )of the Line. and display that vertex on the line how can we do that? i have calcuted route and pass that route(multiline) to GetPointOnALine to find the midpoint (vertex) of the route. but i dosent give me the point.
RoutingEngine routingEngine = new RoutingEngine(routingSource, GetAlgorithm(), featureSource);
            RoutingLayer routingLayer =  (RoutingLayer)((LayerOverlay)winformsMap1.Overlays["RoutingOverlay"]).Layers["RoutingLayer"];
            RoutingResult routingResult = routingEngine.GetRoute(routingLayer.StartPoint, routingLayer.EndPoint);
            routingLayer.Routes.Clear();
            routingLayer.Routes.Add(routingResult.Route);
            //GetPointOnLine method
            PointShape midpoint = new PointShape();
            midpoint = routingResult.Route.GetPointOnALine(StartingPoint.FirstPoint, 100)
I aslo pass 50% but same result.
Second can you explain me how GetPointOnALine function work?
 For the GetPointOnALine, first user pass in a StaringPoint type, which means calculate from the first vertex or from the last vertex, and then passing the percentage of line(you are using this way) or pass in the percentage length with map unit, distance unit together, if you are using the first way, we will default consider the map unit and distance unit as Meter,  so if your data are not meter, it maybe some error.
 Also, GetPointOnALine method only get the point, not create the point, that’s means if your point only have two vertex or don’t have a vertex that fit your distance condition, it’s possible return nothing to you.
Thanks Gray, But my map unit is decimal degree (same my shapefile has decimal degree). if i converted my map unit in meters shape file cannot display and if i converted my shapefile in meters then .rtg file cannot created.
so what is the solution of this problem.
kindly explain this " that's means if your point only have two vertex or don't have a vertex  that fit your distance condition, it's possible return nothing to you. "
So for your situation, you can choose two ways to do this:
            LineShape l = new LineShape();
            //set a percentage of line.
            l.GetPointOnALine(StartingPoint.FirstPoint, 50);
            //know a certain distance in the real world, like 100 kilometer.
            l.GetPointOnALine(StartingPoint.FirstPoint, 100, GeographyUnit.DecimalDegree, DistanceUnit.Kilometer);
Then, " that's means if your point only have two vertex or don't have a vertex that fit your distance condition, it's possible return nothing to you. " if lineshape l only have two points(start point and end point), and you set the percentage 50, so there is no point exist in the middle of line, it will reture nothing. if lineshape l are 200 kilometer long and only have two points, it will return nothing to you.
