How to get zoom changed event
Can i invoke any java script function or code behing file on change of zoom level of maps
Ajay,
We don't have zoom level changed event; but instead, we have extent changed event, depending on this, you can check if current zoom level is changed. You can select For example:
Put the following code in the code behind to register a client extent changed event:
Map1.OnClientExtentChanged = "OnMap1ExtentChanged";
Put the following code the implement the client event.
var lastLevel = null;
var tgMap = null;
var OnMapCreated = function(map) {
    tgMap = map;
var OnMap1ExtentChanged = function() {
    if (tgMap) {
        var isLevelChanged = false;
        if (lastLevel) {
            if (lastLevel != tgMap.zoom) {
                isLevelChanged = true;
        if (isLevelChanged) {
            //...Write your logic here.
        lastLevel = tgMap.zoom;
Let me know if you have more questions.
Howard
