How to hide a popup?
is there a way to close or hide a popup?
My popup is always on the map.
Hi guangming,
 How you generate your popup? I think our popup will be closed if you click the close button on it.
 Please paste some code shows how you build the popup.
I added the close button but when I click it and it triggers another map click event. Then the popup shows again.
 I need to programmatically hide the popup at least, or I have to destroy the popup.
 Also, per openlayer docs, there are many types of popups, which type are you creating?
 map.Popups.Add(new CloudPopup("Information") { AutoSize = true, IsVisible = false, HasCloseButton = true });
Hi Guangming,
 In MVC the cloud popup is using the FramedCloud from Openlayers.
 It looks your close button catch click event but it keep bubble the event to map.
 I found some topic discuss about this problem maybe helpful.
 thinkgeo.com/forums/MapSuite/tabid/143/aft/11198/Default.aspx
 thinkgeo.com/forums/MapSuite/tabid/143/aft/11419/Default.aspx
 thinkgeo.com/forums/MapSuite/tabid/143/aft/11660/Default.aspx
 I haven’t reproduce this in our HowDoISample, if you still have this issue please let us know.
i tried the solutions from your links. It did not work.
 Here is my code and the (2nd) close function never gets called.
 The first one was called (OnMapCreated).
         function OnMapCreated(map) {
             myMap = map;
             if (map.popups.length <= 0) return;
             var i = 0;
             for (i = 0; i < map.popups.length; i++) {
                 OpenLayers.Event.stopObservingElement(map.popups.closeDiv, "click",
                     OpenLayers.Function.bindAsEventListener(function () { this.hide(); }, map.popups));
                 OpenLayers.Event.observe(map.popups.closeDiv, "click",
                     OpenLayers.Function.bindAsEventListener(popupCloseCallBack, map.popups));
                 OpenLayers.Event.observe(map.popups.closeDiv, "touchend",
         function popupCloseCallBack() {
             alert("popupCloseCallBack Created");
             var itemIndex;
             for (itemIndex = 0; itemIndex < myMap.popups.length; itemIndex++) {
                 if (myMap.popups[itemIndex].id === this.id) {
                     myMap.popups[itemIndex].hide();
             this.hide();
Hi Guangming,
 I debug your code, your problem is use map.popups.closeDiv, you should want to use map.popups.closeDiv here.
                 OpenLayers.Event.stopObservingElement(map.popups.closeDiv, “click”,
                 OpenLayers.Event.observe(map.popups.closeDiv, “click”,
                 OpenLayers.Event.observe(map.popups.closeDiv, “touchend”,
                 alert(“Event handler”);
 This will works.
 BTW, please don’t forget assign value to itemIndex.
I did not see the difference. Here is my code again:
 basically, I loop all the popups and set the event for its closeDiv (the close button).
 var i = 0;
                 //alert(map.popups.closeDiv);
                     OpenLayers.Function.bindAsEventListener(closeCallBack, map.popups));
 var i = 0;
                //alert(map.popups[i].closeDiv);
                OpenLayers.Event.stopObservingElement(map.popups[i].closeDiv, "click",
                    OpenLayers.Function.bindAsEventListener(function () { this.hide(); }, map.popups[i]));
                OpenLayers.Event.observe(map.popups[i].closeDiv, "click",
                    OpenLayers.Function.bindAsEventListener(closeCallBack, map.popups[i]));
                OpenLayers.Event.observe(map.popups[i].closeDiv, "touchend",
Hi guangming,
 It looks the system met problem in previous post.
 My modify is map.popups.closeDiv but it shows map.popups.closeDiv.
 Sorry I haven’t double check the reply.
 You’re right, if you don’t use code mode, the [ i ] won’t shows.
 So I think you should solved this problem.
no, it did not. the call back function never gets called.
Hi guangming,
Attached is my test code, you can use it replace your DisplayASimpleMap files in HowDoISamples.
TheTestPackage.zip (1.4 KB)
could not download your code. the link is empty.
 Could you upload it again?
Hi Guangming,
 I have rename the zip file name and update the link.
 Please download it again.
