How to merge two point layers with different colors
Hi all,
   I took the example Refreshing points dynamically , and i was able to plot diffrent points. What i did was i need to put different colors for the points based on their status.
 I tried the below code, it is working but the problem is I have to create different point layers with different colors. Can i have only one layers where points with different color are shown
  public FormLoadShape()
LoadMap();
DrawPoints();
DrawPointG();
public void DrawPoints()
InMemoryFeatureLayer pointsLayer = new InMemoryFeatureLayer();
pointsLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.GetRandomGeoColor(RandomColorType.All)), 5);
pointsLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
for (int i = 0; i < 10; i++)
PointShape pointShape = GetRandomPoint(pointsBoundary);
string id = GetRandomDirection().ToString();
Feature feature = new Feature(pointShape.X, pointShape.Y, id);
pointsLayer.InternalFeatures.Add(feature);
LayerOverlay pointsOverlay = new LayerOverlay();
pointsOverlay.Layers.Add("PointsLayer", pointsLayer);
winformsMap1.Overlays.Add("PointsOverlay", pointsOverlay);
winformsMap1.Refresh(pointsOverlay);
public void DrawPointG()
InMemoryFeatureLayer pointsLayer1 = new InMemoryFeatureLayer();
pointsLayer1.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = new PointStyle(PointSymbolType.Circle, new GeoSolidBrush(GeoColor.StandardColors.Blue), 5);
pointsLayer1.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
pointsLayer1.InternalFeatures.Add(feature);
pointsOverlay.Layers.Add("PointsLayer1", pointsLayer1);
winformsMap1.Overlays.Add("PointsOverlay1", pointsOverlay);
public static PointShape GetRandomPoint(RectangleShape currentExtent)
double x = random.Next((int)currentExtent.UpperLeftPoint.X, (int)currentExtent.LowerRightPoint.X);
double y = random.Next((int)currentExtent.LowerRightPoint.Y, (int)currentExtent.UpperLeftPoint.Y);
PointShape pointShape = new PointShape(x, y);
return pointShape;
public static PanDirection GetRandomDirection()
int i = random.Next(8);
PanDirection panDirection = (PanDirection)i;
return panDirection;
You should be able to do this with a ValueStyle containing two ValueItems. Each ValueItem would contain a string equivalent of the status in the database (perhaps "True" or "1") with a PointStyle for the features with that status and a second (perhaps "False" or "0") with a PointStyle for that status. The ValueStyle gets added to the layer's zoom level CustomStyles collection at the zoom level you want it to apply, probably with an "ApplyUntilZoomLevel" value for what zoom level it ends at.  For starters you can apply it to ZoomLevel01 and make it apply until ZoomLevel20...if there are 500,000 points this will not work well.  When items are added to CustomStyles you can't use the Point/Line/Area/Text Style as well or you get an error. Everything must go in the CustomStyles collection.
The samples included in the package download and here on the Web site have examples of all the three questions you have asked.
Hi Vanlal and Allan,
 Allen is correct in his reply; a Value Style would work very well for this type of situation.
 You can find an example of the ValueStyle in Styles - DrawFeaturesBasedOnValues sample application within the Desktop Edition Sample Applications.
 These sample applications are installed at a default location of Start Button - All Programs - ThinkGeo - Map Suite Desktop Edition - VS2010 Samples.
