How to modify trace of trackoverlay
Hi Team of thinkgeo
I have the next poblem, 2 months ago I started working with snap points (you are near of a vertex and automatically this point is highlighted), when I do click near of one highlighted point, I want my current trace of a line or poligon move to this point.
I would like to know how modify the content of trackoverlay??.
Currently I set trackoverlay invisible and I put the feature traced in trackoverlay in another layer (inmemoryfeaturelayer) but the problem in this case is that I lose the trace of my line or polygon becouse
trackoverlay has this trace and this is invisible..
I don´t know if you understand my problem because 1 mounth ago I posted the same problem but I haven´t received help.
I've attached a picture trying to explain better my problem
thanks for your time
TrackOverlay.TrackShapeLayer.InternalFeatures.Clear()
TrackOverlay.TrackShapeLayer.InternalFeatures.Add(featureChanged)
Abraham,
Thanks for your post.
I am not hundred sure about your requirement, recently, we have done a support on the snapping, hope it was something you are searching:
Also, we have a application in our code community:
code.thinkgeo.com/projects/show/snappingtovertex
If you could find the post you did 1 month ago for your requirement, that would be helpful.
Hi Yale
 well i think I haven´t explained,
 is there a way to modify trackoverlay?? or where is saved this  TrackOverlay.GetTrackingShape
 Look I tryed with this code :
 TrackOverlay.TrackShapeLayer.InternalFeatures.Add(featureChangedBySnapPoints)
 That is good, it puts my modified feature (featureChangedBySnapPoints) in the way I’m waiting but TrackOverlay.GetTrackingShape has another feature, and this feature is still there, although I have done this TrackOverlay.TrackShapeLayer.InternalFeatures.Clear()…
 Now, the question is this??
 Can I modify the origen where is gotten the content of this TrackOverlay.GetTrackingShape?, or can I modify the feature that I’m drawing currently?, not in EditOverlay (I have done this, modify vertex, and it works).
 Thanks a lot.
Hi Yale
 Thanks a lot.
Hi Yale,
 Well I think I have found the solution of my problem, look …
 class SnappingToTrackOverlay : TrackInteractiveOverlay
          protected override InteractiveResult MouseClickCore(InteractionArguments interactionArguments)
             interactionArguments.WorldX = NewWorldXOfSnapPoint;
             interactionArguments.WorldY = NewWorldXOfSnapPoint;
             return base.MouseClickCore(interactionArguments);
 and with this I can modify the current trace I’m drawing…
 regards
Abraham,
 Thanks for your sharing, I appreciate it very much.
Hi
 How can I put one feature in the border of other…
 No more, no less, in the exactly border, something like snap but over polygons…
 For example
 I have a layer of cities and move one city but i would like to get back in the correct place…
Abraham,
I am not exactly sure about your new requirement here, while following 2 samples are talking about how to make the snapping logic with Map Suite 3.x Desktop edition, Could you have a try on them? If they do not satisfy you requirement, please feel free to let me know.
code.thinkgeo.com/projects/show/snaptolayer
