Currently, we don’t provide server-side event support for the world icon. But you can easily get what you want on the client-side using the Javascript event handler for the globe button. If you are using the PanZoomBar control by default, please add the codes below to your ASP.NET page. <script type="text/javascript"> var OnMapCreating = function (map) { OpenLayers.Control.PanZoomBar.prototype.buttonDown = function (evt) { if (!OpenLayers.Event.isLeftClick(evt)) { return; }
switch (this.action) { case "panup": this.map.pan(0, -this.getSlideFactor("h")); break; case "pandown": this.map.pan(0, this.getSlideFactor("h")); break; case "panleft": this.map.pan(-this.getSlideFactor("w"), 0); break; case "panright": this.map.pan(this.getSlideFactor("w"), 0); break; case "zoomin": this.map.zoomIn(); break; case "zoomout": this.map.zoomOut(); break; case "zoomworld": // Here, you can customize the behavior depent on your requirements. By default, it zooms to the max extent. this.map.zoomToMaxExtent(); break; }
OpenLayers.Event.stop(evt); } } </script>
Here is some information about the client-side API for OpenLayers, and I guess it may help you. dev.openlayers.org/releases/OpenLayers-2.10/doc/devdocs/files/OpenLayers/Map-js.html For example, if you just want to zoom to a specific extent and you can call like the code below: this.map.zoomToExtent(new OpenLayers.Bounds(-125, -46, 50, 72));
Please let us know if you have any problems about it.
