I need query InMemoryFeatureLayer,my code:
// this.FeaturesLayer is a InMemoryFeatureLayer , it is point layer and some point show in the osm map;
// wpfMap1.MapUnit = GeographyUnit.Meter; map is online osm map;
//It will realize map click point in the map,get the points’s features (may be get some points,because if points in the new EllipseShape(point, 80, 80));
//add one point in the InMemoryFeatureLayer function code(this.FeaturesLayer have some points):
feature = CreateFeaturePoint(x, y);
feature.ColumnValues[attributeId] = id.ToString();
feature.ColumnValues[attributeLabel] = label;
feature.ColumnValues[attributeType] = type;
feature.ColumnValues[attributeStatus] = status;
this.FeaturesLayer.InternalFeatures.Add(feature);
//some information add in the feature.ColumnValues ;
//However,I using the following code.I can succeed to get the features, but evey feature’s feature.ColumnValues is losed in the features;
//only get the point’s coordinates.
//the point is map click get the point.
IEnumerable<Feature> features=
this.FeaturesLayer.QueryTools.GetFeaturesWithin(new EllipseShape(point, 80, 80), ReturningColumnsType.AllColumns);
IEnumerator enumerator = features.GetEnumerator();
while (enumerator.MoveNext())
Feature feature= enumerator.Current as Feature;
//i need Dictionary<string, string>,like feature.ColumnValues
// string id = feature.ColumnValues[attributeId] // it’s not find attributeId;
Finally,how to query the InMemoryFeatureLayer, use this.FeaturesLayer.QueryTools? Can I query the this.FeaturesLayer.InternalFeatures?
If it can query ,and how to query this.FeaturesLayer.InternalFeatures?
Hi Burning,
The codes look fine but what I guess the issue is happened you are missing to add dbf columns into InMemoryFeatureLayer when creating the instance. Some codes like:
Collection<FeatureSourceColumn> columns = new Collection<FeatureSourceColumn>();columns.Add(new FeatureSourceColumn("attributeId"));columns.Add(new FeatureSourceColumn("attributeLabel"));//..InMemoryFeatureLayer laye = new InMemoryFeatureLayer(columns, new Collection<BaseShape>());
Please try it and let us know if your issues solved.
