How to remove all marker?
How to remove all marker on the map? Which function?
Truong,
 If you are using InMemoryMarkerOverlay, you can use inMemoryMarkerOverlay.Features.Clear(); if you are using SimpleMarkerOverlay, you can use simpleMarkerOverlay.Markers.Clear(). If you just want to remove the markers on the map, you can also try markerOverlay.IsVisible = false.
