Is rotation of raster layers supported in WPF Desktop? We have a requirement for map rotation (both vector and raster data) in our custom application. Here is the code I've tried. The raster layer displays, but I can't figure out the code to rotate it. Thank you for any suggestions!
MapSuiteCore Version 4.5.0.0
Rod
                var rasterLayer = new GdiPlusRasterLayer(layer.FilePath);
                //var rasterLayer = new GeoTiffRasterLayer(layer.FilePath);   //much slower than GdiPlusRasterLayer
                //rasterLayer.ImageSource.Projection = RotationProjection;    //Projection is not a valid property for ImageSource
        //as it is with FeatureSource
                rasterLayer.UpperThreshold = double.MaxValue;
                rasterLayer.LowerThreshold = 0;
                rasterLayer.Name = layer.Id;
                rasterLayer.IsVisible = layer.IsVisible;
                layer.Tag = rasterLayer;
                rasterLayer.Open();
                layerOverlay.Layers.Insert(layer.DrawOrder, layer.Id, rasterLayer);
