How to set Map Width and Height ClientSide
I have a Map control inside an EssentialObject Callpanel, that is inside an EssentialObject SplitterPane. When I resize the Splitter Pane, the Map does not resize with the pane. Any idea how I can achieve this Clientside before the Map is rendered. I know how to trap the PanelResize event but that is were I get stuck since it appears the I cannot assign a value to map.clientWidht or map.clientHeight (where var map = document.getElementById("Map1")).
Any help is greatly appreciated.
Chris
Chris,
You can use the following code. also please have a look at the attached sample for detai.
var map = Map1.GetOpenLayersMap();
map.div.style.width = 1000;
map.div.style.height = 1000;
1222-Post6301zip.zip (93.2 KB)
Ben,
 Thanks - exactly what I was looking for - now if I can only determine what the "real" size of the panel is that contains the map. :) This panel is set to be width=100% and height=100% - that does not work for the map otherwise I would ahve done that from the start.
 Cheers,
 Chris
Chris,
You can set the map to 100% if its parent nodes are also set to 100%. Please see the attached sample.
1226-Post6302.zip (6.17 KB)
Ben,
Alas - it does not work that way under IE8, Chrome, or FF 3.5 :(. I'm not sure what browser you used to test it with. On the mentioned browsers, it just shows a blank screen (essentially, the map has width and height of 0).
I have found a way which seems to work reasonably well by using a combination of
windows.onload = viewPort();
windows.onresize = viewPort();
and
body onload="AdjustControls()"
where the viewPort() function gets the "viewport" of the browser and the "AdjustControls()" function adjust all the controls on the page to fit the viewport
Chris
Chris,
 Another way to implement that is pasting the following style on your aspx page.
 html, body, form, div{height:100%; margin:0px;}
 If possible please remove the DOCTYPE on the aspx page and try again.
 If it still has the issue, please send us a sample and let us see if there is any style issue in your html code.
 Let me know if you have any questions.
 Howard
