Hi. I asked this question in a slightly different way for the web comonent but I have a similar question for the desktop component. I would like to be able to set the scales of the various ZoomLevels, on the map object preferably (I realize it may need to happen to each individual layer), manually as the default zoom levels do not zoom down far enough for certain parcel labels to render. Also, the maximum zoom level is much greater than we really need... I tried to acheive this with the following but it does not seem to work. What am I doing wrong? To note, the scales to get applied to the layers, but I am not getting the above desired results. The scales I picked are likely to change but I just picked these to see if it would work:
Scales(19) = 90000
Scales(18) = 85500
Scales(17) = 81000
Scales(16) = 76500
Scales(15) = 72000
Scales(14) = 67500
Scales(13) = 63000
Scales(12) = 58500
Scales(11) = 54000
Scales(10) = 49500
Scales(9) = 45000
Scales(8) = 40500
Scales(7) = 36000
Scales(6) = 31500
Scales(5) = 27000
Scales(4) = 18000
Scales(3) = 13500
Scales(2) = 9000
Scales(1) = 4500
Scales(0) = 100
Public Shared Sub SetScalesForLayer(ByVal layerToSet As Layer, ByVal Scales As Integer())
If TypeOf layerToSet Is ShapeFileFeatureLayer Then
Dim layerToSetSHP As ShapeFileFeatureLayer = layerToSet
Dim X As Integer = 0
For Each level As ZoomLevel In layerToSetSHP.ZoomLevelSet.GetZoomLevels
level.Scale = Scales(X)
X += 1
Next
End If
End Sub
