How to track vertex in draw mode?
Hi.
I'm looking for event which fires when a vertex is clicked.
For example when I draw a polygon and click on the map then vertex is added, then I click few times and vertices added.
Each time when vertex is added, I need to know the total count.
Which event can provide this informaion?
Thank you.
 Hi Sergei,
There is no any events on the vertex adding in Mvc Edition Api. But we can do this with Openlayers Api. Here is the sample but only works on Polygon and Line shape as Openlayers Api design from here dev.openlayers.org/releases/...er.Polygon
function DrawControls(drawMode) {
        Map1.setDrawMode(drawMode);
        var parserMap = Map1.getMapParser();
        var currentDrawControl = parserMap.paintControls[drawMode];
        if (currentDrawControl) {
            currentDrawControl.callbacks.point = PlusPoint;
            currentDrawControl.featureAdded = function () {
                alert("current feature vertexs: " + totalCount);
                totalCount = 0;
    function PlusPoint() {
        totalCount ++;
<img class="imgBtn" src="@Url.Content(" content="" images="" id="buttonDrawPolygon" onclick="DrawControls('Polygon');" alt="Draw Polygon" />
<img class="imgBtn" src="@Url.Content(" content="" images="" id="buttonDrawLine" onclick="DrawControls('Line');return false;" alt="Draw Line" />
Hope it helps.
