How to use both version of Map Suite Desktop Edition 3.0
How to use (install) both version of Map Suite Desktop Edition 3.0 in the same system to compare their functionality and performance?
I would like to use versions: 3.0.199 and 3.0.307 of DesktopEdition
Pawel,
 Thanks for your post!
 I DONOT think you can install both different versions of product into the same machine. The version 3.0.307 version is just an update for 3.0.199, which shared too many commons files and folders and registry etc.
 SO I suggest 2 solution if you want to compare performance:
 1) Try to install it in different machine with exact same environment. For example, VMs.
 2) Try to write some log in your App, and run it against different DLLs.
 Sorry for the inconvenience.
