I have shapfiles from US Census....decimal degree vs. Mercator
When I try to load shapfiles about US ZIP or Counties it seems that when :WorldMapKitProjection.SphericalMercator;
The shapefile doesn't show on the map  but seems to work when decimaldegree......?????
worldMapKitDesktopOverlay.Projection =
Jean-marie,
While using WorldMapKit in projection "SphericalMercator", you should use your own logic to handle shapefiles' projection transformation. Please check the following code for your reference.
WorldMapKitWmsDesktopOverlay worldOverlay = new WorldMapKitWmsDesktopOverlay();
worldOverlay.Projection = WorldMapKitProjection.SphericalMercator;
winformsMap1.Overlays.Add("WMK", worldOverlay);
ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"..\..\SampleData\Data\Countries02.shp");
worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.SimpleColors.Transparent, GeoColor.FromArgb(100, GeoColor.SimpleColors.Green));
worldLayer.FeatureSource.Projection = proj4;
staticOverlay.Layers.Add("WorldLayer", worldLayer);
proj4.Open();
winformsMap1.CurrentExtent = proj4.ConvertToExternalProjection(new RectangleShape(-133.2515625, 89.2484375, 126.9046875, -88.290625));
proj4.Close();
winformsMap1.Refresh();
Ivan
Works right out of the box!!!
 thanks a lot!
You are welcome!  Let us know if you have any other questions.
