IconValueStyle Z Index
I've created a map that loads a shapefile containing streets. I am using the IconValueStyle class to add a highway symbol to interstates and highways. The problem is that the roads are being rendered on top of the icon. It doesn't matter which style I add to the custom style collection first, the icon style or the value style. Any ideas?
Matt
Would you mind sending us the code where you set up the Styles for your street shapefiles? I think that will help us. Thank you.
I’ve created a map that loads a shapefile containing streets. I am using the IconValueStyle class to add a highway symbol to interstates and highways. The problem is that the roads are being rendered on top of the icon. It doesn’t matter which style I add to the custom style collection first, the icon style or the value style. Any ideas?
I am having the same issue.  Below is my code:
    IconValueStyle iconValueStyle = new IconValueStyle("PRE_TYPE");
    IconValueItem item1 = new IconValueItem("HIGHWAY",
         currentdirectory + "\Support\bitmaps\ushwy-1.gif",
         new TextStyle("NAME", new GeoFont("Arial", 8, DrawingFontStyles.Bold),
         new GeoSolidBrush(GeoColor.StandardColors.Blue)));
    item1.TextValueLengthMin = 1;
    item1.TextValueLengthMax = 8;
    iconValueStyle.IconValueItems.Add(item1);
    iconValueStyle.GridSize = 150;
    iconValueStyle.TextLineSegmentRatio = 10;
    iconValueStyle.DuplicateRule = LabelDuplicateRule.UnlimitedDuplicateLabels;
    iconValueStyle.OverlappingRule = LabelOverlappingRule.NoOverlapping;
    ShapeFileFeatureLayer hwys = new ShapeFileFeatureLayer(shapedir + "\TEST-roads.shp",shapedir + "\TEST-highways1.idx");
    hwys.ZoomLevelSet.ZoomLevel08.CustomStyles.Add(LineStyles.CreateSimpleLineStyle(GeoColor.StandardColors.Black, 2, false));
    hwys.ZoomLevelSet.ZoomLevel08.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level12;
    hwys.ZoomLevelSet.ZoomLevel12.CustomStyles.Add(LineStyles.CreateSimpleLineStyle(GeoColor.StandardColors.Black, 2, false));
    hwys.ZoomLevelSet.ZoomLevel12.CustomStyles.Add(iconValueStyle);
    hwys.ZoomLevelSet.ZoomLevel12.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
 The graphic is a shield, white background, black outline, with the rest of the graphic transparent.
 I have verified that the white part is NOT transparent.
 I need the icon to be displayed on top of the line, not the line on top of the graphic.
 Elisa
Elisa,
There are 2 ways to solve your problem.
1)      Create 2 layers separately. One layer only add the LineStyles, the other layers only add the iconValueStyle, this is the suggested way. Please reference our labeling samples:
HowDoI\ Labeling\ DrawCurvedLabels
2)      Try following code instead without using the CreateSimpleLineStyle to create your LineStyle:
            currentdirectory + "\\Support\\bitmaps\\ushwy-1.gif",
            ShapeFileFeatureLayer hwys = new ShapeFileFeatureLayer(shapedir + "\\TEST-roads.shp", shapedir + "\\TEST-highways1.idx");
            LineStyle lineStyle = new LineStyle(new GeoPen(GeoColor.StandardColors.Black, 2));
            hwys.ZoomLevelSet.ZoomLevel08.CustomStyles.Add(lineStyle);
