IE 10 gives garbled map with Map suite 6
I am using Map Suite Web edition 6.0.0.0 production version.
I am getting garbled map with IE 10 after any three map changes (such as zoom, move, etc.).
The web request produces incorrect tiles.
Since this issue is occurring across all of my websites, I believe it is a dll issue.
Please let me know if this issue is fixed with Mapsuite 7.0.0.0.
Vivek
Hi Vivek,
 You are right. It was a bug and had been fixed since 6.0.0.333. Please get a higher version under Map Suite 6.0 and have a try. But I also recommend you can upgrade to Map Suite 7.0 so that you can obtain more powerful and flexible features.
Hi Johnny,
Thanks for letting me know.
Currently, MapSuite 7.0.0.0 dll are having some issues with my code.
These dlls are not recognizing my client side OpenLayers code of turning on and off the layers.
I can only see Map Suite 7.0.0.0 dlls in my customer portal.
How can get version higher than 6.0.0.33 but lower than 7.0.0.0?
Vivek
Vivek,
Sorry forget to tell you that the customer portal doesn’t provide this function to get the early version except the latest version. currently, I have two suggestions on it.
1. Try to upgrade to map suite 7.0.
2. Add the attached codes in script tag to fix this issue with current Dlls.
thanks,
post11510.txt (3.51 KB)
Thanks Johnny.
Your code works for me.
Vivek
Hi Vivek,
 Good to hear the codes works for you.
 Feel free to tell us if there are any queries.
 Best regards,
