Hi, our map suite is currently suffering from misalingmnet issue as seen in the below link
github.com/openlayers/openlayers/issues/686
The problem seems to be fixed in openlayers 2.13 and I see that there is a new version of Web Edition (7.0) and it promises IE10 support;
but it does not mention what version of open layers is included. With our current version of thinkgeo, it is using openlayers 2.11; so we are wondering if the upgrade to 7.0 will include openlayers 2.13 or if just upgrading will help solve our issue.
IE 10 map misalignment issue
Hi Tracy,
We did intergrate the IE10 support into the WebEdition 7.0 release, including the tile misalingment issue( though the 7.0 is still based on OpenLayers 2.11). Also we tested th tile misalignment issues with kinds of VMs, all works fine, could you try clearing all the browser’s cache and have another try? if it still doesn’t work, would you please try our online map at maps.thinkgeo.com/web/ to check if works fine on your end? if yes, could you let us know the things as following,so that we can try reproducing on our end:
1. What’s your map’s configuration? such as MapUnit, what overlayer you have loaded? etc.
2. Where the problem shows up? debug mode or iis mode? if IIS mode, could you let me know the machine’s configuration of the deplyment server? such as Os version, culture info etc.
Waiting for your further information,
