We have an application, that has a MapView in a fragment. If i open another fragment on top of that and press the back button on that fragment to navigate back to the map, the application crashes with the following exception:
java.lang.IllegalStateException: The specified child already has a parent. You must call removeView() on the child's parent first. at android.view.ViewGroup.addViewInner(ViewGroup.java:5042) at android.view.ViewGroup.addView(ViewGroup.java:4873) at android.view.ViewGroup.addView(ViewGroup.java:4845) at thinkgeo.mapsuite.android.MapView.n_onSizeChanged(Native Method) at thinkgeo.mapsuite.android.MapView.onSizeChanged(MapView.java:63) at android.view.View.sizeChange(View.java:20891) at android.view.View.setFrame(View.java:20852) at android.view.View.layout(View.java:20712) at android.view.ViewGroup.layout(ViewGroup.java:6202) at android.widget.FrameLayout.layoutChildren(FrameLayout.java:323) at android.widget.FrameLayout.onLayout(FrameLayout.java:261) at android.view.View.layout(View.java:20715) at android.view.ViewGroup.layout(ViewGroup.java:6202) at android.widget.FrameLayout.layoutChildren(FrameLayout.java:323) at android.widget.FrameLayout.onLayout(FrameLayout.java:261) at android.view.View.layout(View.java:20715) at android.view.ViewGroup.layout(ViewGroup.java:6202) at android.widget.LinearLayout.setChildFrame(LinearLayout.java:1812) at android.widget.LinearLayout.layoutVertical(LinearLayout.java:1656) at android.widget.LinearLayout.onLayout(LinearLayout.java:1565) at android.view.View.layout(View.java:20715) at android.view.ViewGroup.layout(ViewGroup.java:6202) at android.support.v4.widget.DrawerLayout.onLayout(DrawerLayout.java:1193) at android.view.View.layout(View.java:20715) at android.view.ViewGroup.layout(ViewGroup.java:6202) at android.widget.FrameLayout.layoutChildren(FrameLayout.java:323) at android.widget.FrameLayout.onLayout(FrameLayout.java:261) at android.view.View.layout(View.java:20715) at android.view.ViewGroup.layout(ViewGroup.java:6202) at android.widget.FrameLayout.layoutChildren(FrameLayout.java:323) at android.widget.FrameLayout.onLayout(FrameLayout.java:261) at android.view.View.layout(View.java:20715) at android.view.ViewGroup.layout(ViewGroup.java:6202) at android.widget.FrameLayout.layoutChildren(FrameLayout.java:323) at android.widget.FrameLayout.onLayout(FrameLayout.java:261) at android.view.View.layout(View.java:20715) at android.view.ViewGroup.layout(ViewGroup.java:6202) at android.widget.LinearLayout.setChildFrame(LinearLayout.java:1812) at android.widget.LinearLayout.layoutVertical(LinearLayout.java:1656) at android.widget.LinearLayout.onLayout(LinearLayout.java:1565) at android.view.View.layout(View.java:20715) at android.view.ViewGroup.layout(ViewGroup.java:6202) at android.widget.FrameLayout.layoutChildren(FrameLayout.java:323) at android.widget.FrameLayout.onLayout(FrameLayout.java:261) at com.android.internal.policy.DecorView.onLayout(DecorView.java:903) at android.view.View.layout(View.java:20715) at android.view.ViewGroup.layout(ViewGroup.java:6202) at android.view.ViewRootImpl.performLayout(ViewRootImpl.java:2802) at android.view.ViewRootImpl.performTraversals(ViewRootImpl.java:2329) at android.view.ViewRootImpl.doTraversal(ViewRootImpl.java:1469) at android.view.ViewRootImpl$TraversalRunnable.run(ViewRootImpl.java:7209) at android.view.Choreographer$CallbackRecord.run(Choreographer.java:1050) at android.view.Choreographer.doCallbacks(Choreographer.java:862) at android.view.Choreographer.doFrame(Choreographer.java:797) at android.view.Choreographer$FrameDisplayEventReceiver.run(Choreographer.java:1036) at android.os.Handler.handleCallback(Handler.java:874) at android.os.Handler.dispatchMessage(Handler.java:100) at android.os.Looper.loop(Looper.java:198) at android.app.ActivityThread.main(ActivityThread.java:6729) at java.lang.reflect.Method.invoke(Native Method) at com.android.internal.os.RuntimeInit$MethodAndArgsCaller.run(RuntimeInit.java:493) at com.android.internal.os.ZygoteInit.main(ZygoteInit.java:858)
