Implement Caching with MsSqlFeatureLayer
Hi!
How can I implement cache with sqlserver?
I tried to do the following, but it did not work.
        strPath = System.Web.Hosting.HostingEnvironment.MapPath("~/tiles")
        loFileTileCache = New FileBitmapTileCache(strPath)
        loFileTileCache.TileAccessMode = TileAccessMode.ReadAddDelete
           'Lineas
            mssqlFeatureLayer = New MsSqlFeatureLayer(ConnectionStr, "mags.WEB_EL_v_Lineas", "Linea")
            mssqlFeatureLayer.Name = capa
            mssqlFeatureLayer.CustomGeometryColumnName = "Objeto"
            lo_LineaValueStyle.ColumnName = "Alimentador_MT"
            mssqlFeatureLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(lo_LineaValueStyle)
            mssqlFeatureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20
            mssqlFeatureLayer.FeatureSource.Projection = proj4
            layerOverlay.TileCache = loTileCache
            layerOverlay.Layers.Add(mssqlFeatureLayer)
And I get this error
“Object reference not set to an instance of an object.”
Thank you
Regards
Abel
Hi Abel,
Thanks for let us know this problem.
Your exception is easy to be fixed but after that some tiles cannot be saved correct, our developer is working for that and we will let you know after we complete it.
Hi Abel,
It had been fixed, please try the
or
And please let us know whether it works for you.
