I am trying to create a globe that can be rotated, similar to Google Earth. Is there any built in ThinkGeo functionality to handle this, or any sample projects demonstrating a globe?
I am able to achieve a 2D image of the globe projection with a certain center lat/long point using ProjectionConverters with the Lambert Azimuthal Equal Area (+proj=laea) projection string. I put together a very rough rotation by updating each layer’s ProjectionConverter +proj=laea string every time I pan the map. For example, “+proj=laea +lat_0=” + LatModifier + " +lon_0=" + LongModifier" where changing latModifier and longModifier will recenter the projection at that point. The modifiers are based on how far the pan tool was clicked and dragged. This leads to a very choppy experience since it requires updating each layer’s ProjectionConverter string and refreshing the map on each pan.
Please let me know if there are any samples using a 3D sphere/globe projection or any alternative for creating a rotatable globe besides constantly reprojecting +proj=laea with different center points.
Dane
