Currently we are using Version 8. As now Version 9 is out we have tried to run application on new version to check out differences. On first look I found fonts are displayed differently. Here with this I have attached both version images. In version 9 fonts looks more dark and big. Also geofont looks zigzag. Please guide what to change to show like previous version.
version 8 image
version 9 image
Goral
In version 9 font changes
Hi Goral,
Could you please upload a sample which can reproduce that, it looks you haven’t use the same image between 2 image, and I am not sure the font with same code. Or if you found the same problem in our sample should be helpful.
I have created one test application. Here with this I have attached .cs file and image file from two version. Please go through it.
version 8
Version 9
Goral
frmFontTest.cs (3.63 KB)
Hi Goral,
Thanks for your code, I don’t know whether that’s caused by your environment issue. I suggest you reinstall our product and test again.
As below is my test result, I tested your code with our latest code and WpfDesktopEditionFull9.0.20.0DllPackage dlls, it render just the same like this:
Thanks for reply, We are using Winform Desktop Edition. In your reply you have mentioned about WpfDesktopEdition. Please confirm about it.
Goral
Hi Goral,
Sorry I tested that in WPF edition. Today I test your code again, with latest code and the dlls from DesktopEditionFull9.0.20.0DllPackage.zip.
The test result as below:
So I think it’s still be an environment issue. Could you please test that in other machine or VM machine?
Thanks for reply. I have tried to re install but still its same. Can you please suggest what to check in environment issues?
Goral
Hi Goral,
I think that’s maybe related with two factors:
1. Some of your dlls hadn’t been updated to the latest. You can try to uninstall original version and install our latest version for try fix it.
2. Some setting like font in your OS. You can try to restore default setting of them.
But I still suggest you test that in a clean VM machine first.
