Incorrect projection?
Hi all,
I am trying to use the MapSuite to display an airport map. When I convert the map to a new projection,I get a ploblem that the map does not show.  Because the map is Riga Airport, so I think <3059> should be the right one. That's right? And If remove the line "TaxiwayShapeLayer.FeatureSource.Projection = proj4Projection;", it works well but the map seems distorted.
Attached is the map shape files.
Please help with this problem.
Feng
The code as following:
 private void UserADifferentProjectionForAFeatureLayer_Load(object sender, EventArgs e)
             winformsMap1.BackgroundOverlay.BackgroundBrush = new GeoSolidBrush(GeoColor.StandardColors.Black);
            // If want to know more srids, please refer Projections.rtf in Documentation folder.
            Proj4Projection proj4Projection = new Proj4Projection();
            proj4Projection.InternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(4326);
            proj4Projection.ExternalProjectionParametersString = Proj4Projection.GetEpsgParametersString(3059);
            ShapeFileFeatureLayer TaxiwayShapeLayer = new ShapeFileFeatureLayer(@"D:\Maps\taxiway.shp");
            TaxiwayShapeLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            TaxiwayShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle.OuterPen.Color = GeoColor.StandardColors.GreenYellow;
            TaxiwayShapeLayer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle.OuterPen.Width = 1;
            TaxiwayShapeLayer.RequireIndex = false;
            staticOverlay.Layers.Add("TaxiwayShapeLayer", TaxiwayShapeLayer);
           winformsMap1.CurrentExtent = new RectangleShape(23.963333333, 56.933333333,23.99166666666666667, 56.916666849);
            winformsMap1.Refresh();
EVRA.zip (90.9 KB)
Hi Feng,
Welcome to MapSuite discussion forum.
Thanks for your sample code and data that help us easy to recreate your problem. I think you set the wrong current extent, I calculate the boundingbox with projection, you may use "497964.835015259,308890.33094185,499005.460015259,308147.83094185". And also <3059> is a tmerc projection which use meter as unit, so you need to set MapUnit to Meter as well.
Feel free to let me know if you have more questions.
Hi James,
Thank you for your quickly reply.  With your help I resloved the problem.
An other question: How to calxulate the boundingbox? I am a greenhand in GIS.
Thanks agagin.
Feng
Feng,
 You’re so welcome.
 MapSuite provides many APIs for GIS function. After you set Projection to layer.FeatureSource.Projection, you can first call layer.Open(), and then call layer.GetBoundingBox() to get full extent of this layer, finally call layer.Close() to dispose the resource.
